Browse Forums Heating, Cooling & Insulation Re: York 26kw 3-phase Inverter Reverse Cycle Ducted system 2Oct 30, 2020 2:43 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: York 26kw 3-phase Inverter Reverse Cycle Ducted system 4Oct 30, 2020 2:59 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: York 26kw 3-phase Inverter Reverse Cycle Ducted system 6Oct 30, 2020 3:18 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: York 26kw 3-phase Inverter Reverse Cycle Ducted system 8Oct 30, 2020 3:37 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: York 26kw 3-phase Inverter Reverse Cycle Ducted system 11Oct 30, 2020 4:09 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: York 26kw 3-phase Inverter Reverse Cycle Ducted system 12Oct 30, 2020 4:17 pm chippy Firstbuild20 chippy The York website seems to indicate that you can get WiFi controllers that can also work on your mobile phone. I would be amazed that you can't at least install a slave controller upstairs. Maybe the builder isn't interested in asking the question or hasn't prewired for a slave controller. Just ring York and see what they recommend. Thanks for the information. Our builder has told us that WiFI controller is not an option for our unit. I hope we can get the model and serial number information from our builder so that I can check with Bonaire/York as I no longer trust our builder. We paid almost $25k for this unit so we are very disappointed. If in case they didn't prewire for a slave controller, would it be possible to add later on for a double storey? And would it be possible to add another controller upstairs for an existing unit? I think this is the unit you have. The top number is the model of indoor unit and the number below is the model of the outdoor unit. It's the only 26kw 3phase unit they have. Ring York/Bonaire with the model and ask if it's possible to run 2 control units with that system. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks. I will ring York/Bonaire to confirm if the unit can run 2 control units with this system. 1 62023 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
