Browse Forums Heating, Cooling & Insulation 1 Sep 30, 2020 10:25 am Hi, I need to get the ceiling fans replaced in all rooms at our investment property (small size for bedroom, large size for living areas). The ceilings are only 2.4mtrs high, so I want to get low profile fans. I need 4 curved blades, white, with light - AC or DC (prefer DC for the environment but might need to not be picky on this point) Can anyone provide a link of where I can purchase above? I've done hours of google searches but yet to find the right thing. I have found a few 3 blade but it sounds like 4 blade is better in hot areas - not sure if this is true or not. Thanks Julie Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8992 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10682 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5929 |
