Browse Forums Heating, Cooling & Insulation 1 Sep 02, 2020 11:33 pm Hi everyone. I think I might have a problem. I turned my Rennai 12k ducted air conditioner on to warm the house. I left for work and hoped that my adult daughter would turn it off when she was leaving for work, which she did, but only turned the two zones of. When I arrived home from work around 8 hours later, I found that the compressor had been on all day. Have I caused a problem Re: Ducted air conditioner 2Dec 23, 2020 9:20 am Is the unit still running correctly once you turn the zones back on. Does the unit still turn off when turned off correctly? Try a process of elimination to determine if you have an issue. Usually turning off zones won't always turn off the actual unit, it will simply stop airflow to those areas and leave airflow running to the "common" area. So it is likely that the unit was running all day because it was not turned off correctly. Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 0 6294 |
