Browse Forums Heating, Cooling & Insulation Re: Actron Air conditioning ducting ESP Series vs Daikin 21Feb 15, 2013 8:59 pm I see what you mean about reputable tests I guess they expect people to trust them based on their reputation Don't get me wrong Nothing wrong with Inverters I have friends with both systems and plenty get sold every year Both seem to have advantages over each other as most things inevitably do Starting power, vermin issues, cost of repair, part availability controls etc But I cant find anything about energy savings on the cooler days on the other brands either Do you know where I can read something about part load savings for brands like Daikin, Fuji and Mitsubishi? What do the others say Where can I find that info ? Anyone got a link? Re: Actron Air conditioning ducting ESP Series vs Daikin 22Feb 16, 2013 7:14 pm Actually after careful consideration and speaking to friends, I've decided to go with the Actron ESP + Ultima series. I've been informed it doesn't require a constant zone, and it is energy efficient. I pay a bit more on extra controllers, but the good thing with the Ultima series is you turn on the main controller and set it to 24 degrees, and set it to the room you want to cool. So let's say I want to cool Bedroom 1 and 2. I go to the main controller and turn on bedroom 1 and 2, but in Bedroom 1 and 2, I can turn the temperature 3 degrees up or down. With the Daikin Ducted, for a 12.5kw, I'll still need to have a constant zone turned on, which in my opinion, I'll be wasting $$$. I'm in no hurry to purchase the Actron until the retailers throw in some special offers. Hopefully in July or August in Perth. Re: Actron Air conditioning ducting ESP Series vs Daikin 23Feb 17, 2013 1:05 am Sending this reply from just south of Karratha. It gets hot up here. In Industry where cost just doesnt seem to matter as much theres a standard in electrical substations etc......................Its called Daikin. Many years ago my Father owned 'Karratha Refrigeration " It was impressed on me that the only brand rated to perform in 46deg was Daikin. Maybe time has changed the clear Product lead that Daikin had but it still Dominates up here(Market Lead) in the Pilbara and North west. I installed Daikin Ducted in my House in Perth, had it on the two houses I built in Karratha and am getting Daikin Ducted in our new Dwelling in Northam. I havnt had a failure of any units in service. In my book and in heavy Industry Daikin is the Mercedes of A/C. im not trying to pump my tyres up here I'm just saying it's the Industry standard. Seriously I wouldnt even contemplate anything else..................but I dont give a rats about cost, i'm not into penny pinching and calling fridgies up. Saving money on quality stuff done right firstime Our Build Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=66810&p=1094349#p1094349 Re: Actron Air conditioning ducting ESP Series vs Daikin 24Feb 17, 2013 12:29 pm the issue is that Actron is provided free from some builders.... and while we can upgrade to the better systems, the builder won't let you swap to a different brand without paying for the entire system, this also does not really cover us as a comprehensive independent review, to this end I've filled out a few "request a test" forms on choice: http://www.choice.com.au/reviews-and-te ... 2eba3&_z=z Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Actron Air conditioning ducting ESP Series vs Daikin 25Feb 18, 2013 6:19 am Ah Aircon is never free Just hidden in the price I think the builders have to let you take it out of the contract if you want I had a mate who threatened to go with another builder Then they let him change Depends whether you have signed a contract before or after you try and change a major inclusion like Air con Sometimes pays to get your building plan and check with a couple of reputable contractors that Check the following What size would they recommend How many zones and duct etc What is your builder giving you and does it cover what a specialist would recommend Re: Actron Air conditioning ducting ESP Series vs Daikin 26Feb 18, 2013 6:55 am not exactly how it works.... the free aircon deal is now removed, and the price of the contract is now the same (in our case) Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Actron Air conditioning ducting ESP Series vs Daikin 27Aug 27, 2017 9:02 pm The Copeland compressor uses about 7.5% of power when not under load. They are used because they can control temp very accurately, are simple requiring few electronics, are very robust and reliable and relatively cheap to fix. Inverters are complex and can be very expensive to fix when electronics fail, compressors don't like running at less than full speed requiring oil return cycles, under field testing where an inverter compressor is not locked to a certain speed they are often a lot less efficient than their rated eer's or cop's, when locked they should be more efficient at part load Their are a number of independent papers discussing this, suggesting new testing standards are required for inverters. Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 10046 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 9701 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6294 |
