Browse Forums Heating, Cooling & Insulation Re: Roof insulation and building code 21Sep 21, 2020 4:51 pm Arrhhh starting to make sense now, I've seen them and wondered when they were used. If I put a blanket over the top will it still insulate well if the batts sit slightly higher than the joists? Do you have the foil at the top or bottom when its laid out? Can you have 2 blankets on top of each other one with foil at the bottom to reflect heat into house for when its cold and one with foil at the top to reflect heat away from the house when its hot? Or does it not work like that Thanks for answering all my questions Re: Roof insulation and building code 22Sep 21, 2020 5:08 pm Foils needs to be placed at the top, to prevent extra heat coming from the roof space. But yes, you can do it either the way you described or the bottom blanket can be just without foil. The only concern is that when during hot summer days the heat from your house rises to the top and will be stuck between your ceiling and a roof space mostly, so ideally you would need to have some reliable way to vent it out from there back to the roof space (from where it then can dissipate through the eaves overnight). Re: Roof insulation and building code 23Sep 24, 2020 9:28 am How do you let the hot air escape into the roof space? Cut a hole in the ceiling and have a fan pull it up into the roof space? CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17602 1 1103 |
