Browse Forums Heating, Cooling & Insulation Re: Ducted Split System / Electronic heating and cooling cos 14Jul 17, 2018 4:06 am It will not cost you a fortune. Unlike resistance heat, which uses electric elements to generate heat, a minisplit heat pump (MSHP) moves heat from one location to another using refrigerant, a compressor, heat exchangers, and an expansion valve. During the summer, an MSHP moves heat from inside the building to the outside. During the heating season, the unit operates in reverse, capturing heat from the outside air and moving it into the home. Since the heat source for these units is air, they are commonly referred to as air-source (or air-to-air) heat pumps. Because ductless MSHPs are point sources of heating and cooling, this often makes them best suited to reducing the energy demands of a central heating system rather than replacing the system entirely. In a new, well-insulated and sealed home, many designers combine heat pumps with strategically located electric resistance heat in bathrooms and other critical areas to avoid the need for a central heating system. Move your linen into laundry and access laundry from your present linen space 1 8002 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9780 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
