Browse Forums Heating, Cooling & Insulation 1 Apr 22, 2018 2:29 pm Hi all, I have a Braemer gas ducted heater (about 10 years). Had a service guy who came out last week to clean the ducted heater. After cleaning for an hour my ducted heater isn't working anymore. The heater runs for about 15 mins then stops (display panel shows reset). After resetting , it runs for around 10mins. Then the flames goes on and off every 3 second from the main. He has changed the ignite sensor and some white cable sensor. But it's still showing error code 7 ( gas locked out). In between his cleaning he had to cut the air vent silver tube underneath the house to retrieve part of his cleaning tool which disconnected into the vent). If he didn't join /seal it back properly, could this be the cause? Thanks in advance. Re: Braemar has ducted heater issue 2Apr 24, 2018 9:42 am Have you approached Braemer - or the person who did the job ? 0 1724 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 6817 My Electrical roughing is going on. What type of Outdoor heater recommended in Alfresco sized 3000mm x 3000mm below. I asked electrician to give 15amp power point in… 0 2118 |
