Browse Forums Heating, Cooling & Insulation Re: Air Con - Excessive Noise at Start-up (Daikin) 10Sep 12, 2016 11:06 am Working well - so if anyone has the same problem it might be the answer. How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6626 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
