Browse Forums Heating, Cooling & Insulation Re: Wood fired Hydronic radiators vs hot air transfer kit? 3May 24, 2015 6:38 pm Our Build Here: viewtopic.php?f=31&t=74037&p=1255246#p1255246 Re: Wood fired Hydronic radiators vs hot air transfer kit? 5May 27, 2015 4:43 pm Crazyk We have a wood stove with Hydronic radiators on our acreage and it is the best thing ever. If you do it and are prepared to cut the timber I would do that any day over an air transfer kit. Air transfer kit is the same as ducted heating. Radiators are far more efficient and will radiate heat to heat object thus eliminating cold spots in the room. Remember, air transfer kits will be blowing from the ceiling so your pushing hot air from the top of one room to the top of another...My feet get cold at ground level ! Yeah I'm starting to think this is the way forward. Having a look around there are some really efficient fires with high capacity boilers built in. Your right trying to blow hot air down doesn't make sense. Our Build Here: viewtopic.php?f=31&t=74037&p=1255246#p1255246 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 5327 Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 5377 We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is… 0 5450 |
