Browse Forums What's New 1 Sep 29, 2019 8:24 am If your build is non compliant with relevant Codes then alternate solutions are acceptable under certain circumstances Process Guidelines Here 1.Prepare a performance based design brief 2.Carry out analysis, Modelling or Testing 3.Collate and Evaluate Results 4.Prepare the final Report Development of Performance Solutions If you believe your Build is non-compliant and the proposed Alternate Solution is unacceptable and poses a risk you now have recourse, you will also be required to collect/provide Data and Proofs during the build, ie photos, measurements, calculations, engineering,etc More to follow Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: New NCC Development Of Performance Solutions and Evaluat 2Dec 17, 2020 7:24 pm Hi StructuralBIMGuy, In relation to 'performance solutions', are you able to consult me on the conversion of a class 10a building to a habitable space? Thank you Re: New NCC Development Of Performance Solutions and Evaluat 3Dec 17, 2020 10:54 pm Hey Yiannakis50 Welcome to the forum Classification of Class 10a Not sure if you are converting a shed or carport? If you wish to convert an existing shed to a dwelling you will need to obtain a building permit, complete a certified or uncertified application and have it assessed by a Building surveyor. All requirements of a normal building permit application still apply, but you will also be required to engage an engineer to assess the building's suitability for conversion. Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: New NCC Development Of Performance Solutions and Evaluat 4Dec 18, 2020 6:31 am I'm doing an extension/renovation as an owner builder. I'm basically joining the existing house to the garage and converting the old garage into a rumpus room/office/toilet/storage. My draftsmen has completed the working drawings and I'm in the process of obtaining the building permit. My Building Surveyor (BS) has charged me $3500 for his works and to issue the building permit. So everything up to here I was fine with. Last week, my BS requested I consult a Building Consultant to obtain 'Performance Solution' (previously called Alternative Solutions) in converting the garage to a habitable structure. These 'Performance Solutions', will need to cover weatherproofing, finished floor level, slab dampness management for the garage conversion, termite and fire protection. This is were my issue begins. Firstly, my draftsmen has already addressed this in the plans. Secondly, I obtained a quote from a building consultant and the cost of the garage is more then the total surveying for the build. Is there a way around this? Is there an alternative solution? and does this process sound legit or is it a money grab? Thank you Re: New NCC Development Of Performance Solutions and Evaluat 5Dec 18, 2020 11:01 am To avoid friction between private Building surveyors and the Council building surveyor and undue additional expenses I suggest you get an engineer to sign off then get it privately certified, your designer should have explained this. OT, follow the codes for compliance, If it's not in the codes then get an engineer to sign off... don't waste time and money with artists, designers and architects as their data/ proofs/solutions have to be verified and checked. This problem is further compounded with the use of Bim software simulations where the person offering it up has no idea if it is correct or not. A good engineering solution will use simulations and back it up with approximations Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs thanks guys! yes this is how I've exactly raised it with the builder. still awaiting response. 12 6333 Hi We are building in the Hunter Valley, our soil test is H1, our builder has advised us they need to have a letter signed for Fair Trading as the new drainage standard… 0 3734 Whats in the gap between the fence and the concrete? I assume dirt/plants etc, right? like youve shown in other parts of the pics. Im not sure how familiar you are with… 8 6212 |
