European Shower - starting to be popular in Perth
Page 1 of 2
No Hob
No shower screen
keeps the wife happy as less cleaning
And the shower channel when putting in one of thes a must, the one against the wall, what do others think.
WA
DP is a tile showroom manager so he'd lurrrrve it since he'd get to be surrounded by tiles, haha.
Less chance of showerscreen breakage, more privacy, less visible soapscum etc, we splash water all over the floor anyway so it wouldn't matter about it being one level or having no shower curtain (shower curtains are manky anyway!). Mmmmm, I like
The only thing I'd worry about is lighting... do you need a separate light to light up the shower area (since a wall obviously isn't clear/opaque like a glass shower screen)
In our electrical plans we put a light directly over the gap where you walk into the shower so it shines into both the shower and the main part of the room.
Typically does the wall go all the way to the ceiling?
A great picture of the shower regarding this discussion. However many variations such as double shower heads (his & hers)
Cyberman the wall on our plans will go all the way to the ceiling, however you could perhaps opt for an opening at the top or a highlight window at the top, however our objetive is to reduce the cleaning and a wall to the ceiling would achive this for us. as for lighting you could face the shower entrance towards the bathroom window, which we have opted for a highlight here and as ling as the light is flush with the ceiling (not a surface mount) or an IP65 rating you can install a light within the shower recess, we are opting for flush light fittings such as low voltage downlights. if you look at the above picture a highlight window has been installed as you can see the light hitting the wall of the shower.
As for cleaning highly recommend the channel made from stainless steel and that the one which the grate top can be removed for cleaning.
IMO a great way to a shower built.
Less cleaning
Less silicon
looks great (my opinion and based on taste/design)
Who thought of the shower hob and shower curtain.... discusting and an eyesore IMO
1. the cleaning I hate glass screens with water marks
2. I think that for the water on the floor of you shower would get away more efficiently with this grate than the round 1 in the middle of the shower floor (less chance water will spill out IYKWIM)
3. I think the look a bit resort style
Our tiler was VERY happy about it, he said less work for him, with cutting ect
Except we're having a smart tile instead of grate
Totally agree with your comments.
Has the KISS statement written all over it.
If installing this style of shower I would recommend the grate or the smart tile (smart tile as you mention), I just prefered the ease of cleaing the grate and that it's stailess steel and don't mingd the industrial look.
I had seen one of these showers in a display home in my area, with your common round drain in the shower where you would stand, a disaster wating to happen as this would create the water to build up, standing on it and the build up of water (more input than output).
If installing one of these you would need a reflux valve installed to the waste pipe in the plumbing about $300 but needs to be done at the start or with a major bathroom reno.
Cheers,
WA
No shelf hanging out into your space.
Our bathrooms should be tiled in the next couple weeks so, check my thread and watch as they appear.
Nice showers though!
They seem to take up more space than the usual style though...
We will have a walk-in shower in both the ensuite (1.6m x 1.0m) and the bathroom (1.6m x 0.9m). However I hate the feeling of being enclosed with the all tile showers and also love showering in natural light. So we are having a fixed glass pane for the side wall for our ensuite and for the side and one end of the bathroom shower.
Yes, I know, lots of glass to keep clean, but better than feeling claustrophobic.
Ruth
What's a smart tile?
Next time the European shower will be a non negotiable must have. Anything that cuts the housework must be good.
2
Thanks for that!
27/06/2023
2
I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks
22/06/2023
Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to…
