Browse Forums Landscape & Garden Design 1 Jul 24, 2020 9:39 pm Hey guys Me and a friend are doing some concreting under our pergola. His more a handy man then me, but I am trying to find out some info to do as much as I can myself because his a bit busy. We are up to connecting a storm water pit and drain. Underneath there is an existing storm water pvc pipe. I think its 90mm but I can only go off the size of the other storm water drains in the backyard So I just want to know if this is all I need because I dont want to spend much time looking for stuff and finding someone to help me in bunnings. I want to get in and out asap T angle 90mm PVC pipe like this – https://www.bunnings.com.au/holman-25mm-press-pvc-plain-tee_p3142350 2 of these – https://www.bunnings.com.au/deks-90mm-pvc-stormwater-coupling_p4730188 90mm PVC Pipe – 1-2 meters of 90mm PVC pipe Grill – https://www.bunnings.com.au/everhard-easydrain-polymer-grate-to-suit-flo-way-pit_p4771607 Questions. I see some people have storm water pitt's like this – https://www.bunnings.com.au/everhard-325mm-series-300-shallow-stormwater-pit_p4771398 Not sure if I need this or not. I think they hold the water before drain and act like a sink. The storm water would be under our pergola and would only get water from the run off from just outside the pergola and when we clean it with the hose Glue? https://www.bunnings.com.au/protek-125ml-type-n-blue-cement-solvent_p4750114 This guy didnt use any for the couplings. https://youtu.be/WxRN9-Y3eZ8 Re: Connecting Storm water drain to existing pipe 2Aug 05, 2020 5:53 am All looks good to me Patrick. I'm no pro plumber or anything but the products you have pictured look like they will do the job. Pits help keep debris from sliding down your underground pipe run, they can also help regulate flow. They are a great idea but don't always suit the area where stormwater underground piping is installed. Common to see them put somewhere inconspicuous. Good luck .. Re: Connecting Storm water drain to existing pipe 3Aug 05, 2020 7:29 am Hey Bluehorse Bunnings is going to lockdown in Victoria here Retail will look very different : Bunnings stores to close The irony is I've never been so busy with construction, engineering and 3D Bim my2c....Forget Click and collect...you can now go directly to online Suppliers and Wholesalers with your 3D Details, Quantities with House lot and large orders, save a bucket load of money! How to decide on a builder (and material,Costs, compliance,etc) without quotes Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs I don’t have any drainage points at the backyard from the builder. And got flooding issue when it is raining. And now I am about to start doing my landscaping . For… 0 558 Without having looked into it, I thought maybe it was a maximum threshold, where a design may technically be spec'd at say 13m but the code (because of its performance… 7 4207 I ended up getting a and from Bunnings. I connected… 9 3643 |
