Browse Forums Landscape & Garden Design 1 May 15, 2020 3:22 pm hi, I'm baffled with solenoid valves and hoping someone can help. I'm on my third type, all purchased from Bunnings, and all have the same problem. I'm using the 25mm 24VAC non-latching type, I tried Holman, K-Rain and now Pope and they all have the same problem – when de-powered they won't block water flow. Am I doing something wrong? These things are pretty simple – apply 24VAC to open, power off to close. I connected them to my water pipe: power off, turn on the water and no water flow – great, as expected. Power up - water flow, great, as expected again. Power off again and still water flow! The Pope is the worst, you wouldnt even know its off, K-Rain was better it blocked maybe 90% of water, Holman in between. I tried reducing the water pressure at the tap as well, no change. Before I resort to the latching type I'm hoping someone can tell me I'm doing something wrong. Is there an extra step I'm missing? Thanks for any advice, Will. Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6934 You may still have a case, but your next step is to speak to a lawyer. 3 1573 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20034 |
