Browse Forums Landscape & Garden Design 1 Apr 12, 2020 11:13 am Morning all, I've got a well-established couch lawn (I'm not sure exactly what type it is), but over the last few months I've noticed a section of it that appears to be starting to be overrun with another type of grass. The side by side photo has my original lawn on the left, and the new interloper on the right. As you can see, they are relatively similar, but definitely different grasses. The new one is quite soft underfoot, whereas my old one is a bit spikier to walk on. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The bit I've circled in red is what it looks like in the ground. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any ideas on what the new one is? If I had to take a guess, I'd have said it is just another different type of couch, but I freely admit I have no idea. Thanks. Re: Please help me identify this lawn 3May 06, 2020 2:28 pm Every now and then I do get paspalum, but it looks more like the photo below (ie. fairly isolated and quite broad leaves). The one I'm battling has a finer leaf and blends in fairly well with my current couch lawn. On some days, in the right light, it is almost indistinguishable from the rest of the lawn, but on other days it is a bit shinier and greener (vs. the duller-green of the couch). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Please help me identify this lawn 6May 06, 2020 9:21 pm Maybe just a different variety of couch: https://www.google.com.au/amp/s/returf. ... grass/amp/ Re: Please help me identify this lawn 7May 06, 2020 9:27 pm Subtropic Maybe just a different variety of couch: https://www.google.com.au/amp/s/returf. ... grass/amp/ That website has some info which I donβt think is a good for healthy lawns including mowing to 20mm and advocating chemical fertiliser Re: Please help me identify this lawn 8May 06, 2020 9:39 pm Take a sample to a nursery, they will know. BTW, I get them in my front lawn and nature strip and I am in Melb. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. the leaves that are now underground go yellow, the tips that poke through photosynthesise and have chlorophyll, same reason they grow rhubarb in the dark. 5 4815 Thankyou so much π I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK π 2 7073 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12624 |
