Hi
I need to make some steps to the front door thinking of Corten risers with stabilised crushed concert for the steps
The run length is 5000 and the height 1300
Ive calculated 5steps riser 250mm step 1000 preferred or 6 steps 210mm riser and 830 step
Would these be comfortable /legal
Any suggestion comments welcomed
Nick
Max step risers are 190mm I understand this is landscaping but I would work with a max 190mm step as they are comfortable.
I must say sometimes long treads are awkward especially when you find you are taking lunges to the next riser.
Post some update pucs
Thanks for the reply
What about 6 steps(7rises) rise 183mm step 830mm is there an optimum step would prefer longer step
Should the step (run/going) be able to accomodate 1 or 2 footfalls (1foot on the step other foot on next step or both feet on step then
climb to next step)
Am I making this too complex???
climb to next step)
I've no clue how I'm going to achieve this but this is how it's designed for my about to be built house. Mixed shaped risers.
you should never mix the riser height and try your best to keep all your risers to be of the same height. As otherwise, risks of slip and fall will be higher, as the brain can't fast switch/accommodate to changing risers when you are quickly walk/running down.
182-190 mm is the perfect riser height, 200 mm is already quite steep.
I thought BCA mandated consistent step height. Least it showed up on my recent building and.pest report. Possible public liability issue.
BCA says you have 5mm tolerance between step heights only, all measurements in heights should be the same across the whole staircase.
climb to next step)
chennaiiteI think what you meant to say was different size goings.
In modern landscaping it's common to mix a couple of steps with big landings of different sizes. It helps break up the look of the hardscaping.
You will find that the risers will be the same height.
The pictures below are a job I did a few weeks back. All the risers including the ones up to the front entrance are the same height, but once you are of the actual flight of stairs and into the hardscaping the landing sizes change. Looks like you even have some negative details on the risers which always look good.
