Browse Forums Landscape & Garden Design 1 Jan 25, 2020 12:04 pm Hi - I’m worried my 1 year old wollemi pine is dead but I’m hoping someone can help me rescue it! Basically, a month ago it was looking pretty healthy, then I went away for 2 weeks at the start of January and came back and it looked dead. I’m based in Sydney where we’ve had some extreme heat days (high 30s, 40+). I checked the moisture level in the soil (stuck my finger in about 5cm) and gave it some more water. Pot is about 300m diameter by 300mm deep. I used the potting mix as recommended by the garden store where I bought but have not replaced it since (was planning to do so at the end of summer). See below a photo where it was looking healthy a month ago, and then a few current ones where it looks terrible. Thanks for any help/advice you can provide! Looking healthy a month agoLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Can I save my wollemi pine? 2Jan 25, 2020 3:17 pm It looks to me as though it just dried out, probably because the pot got too hot. I would move it into a cooler spot in your garden and give it plenty of water. Pots outside often need to be watered daily through heat waves. If you're not able to do this then you can bury pots partially underground to keep them cooler during hotter months. I've just had a look at the website. The company are just building broker's. There are plenty of similar companies that basically draw your plans (they own them so you… 8 10945 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6591 I’m just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52858 |
