Browse Forums Landscape & Garden Design 1 Jan 21, 2020 11:53 am Unfortunately in that crazy Sydney storm last night I wasn’t home to even try to protect some of my plants. The hardest hit (to both the plants and my heart) were my giant elephant ears that were the backdrop to my kitchen splash. They have been in for about 8 months and had some leaves that were almost 1m long! The plant seems to have started only sprouting small leaves as of the last month, almost like it knows that’s all it has room for! I’m wondering first of all whether these plants are too damaged to recover, and secondly whether I should be removing some of the damaged leaves. On one plant literally every leaf is smashed and I’m worried about the plants retaining nutrients and having enough surface area to get sunlight. Appreciate your help. Before Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ After Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Plants and hail damage 2Jan 24, 2020 3:08 pm Just prune the damaged stalks down to main stalk leaving about 1-2cms space from the 'trunk'. Use a sharp flat blade kitchen knife if the tuber is thick, just to make sure you get a clean cut. Minimise the surface area on the stalk ( cut perpendicular ) as they lose moisture for a while due to the cut. Dose with seasol and molasses before pruning. Re: Plants and hail damage 3Jan 25, 2020 1:44 pm ![]() Just prune the damaged stalks down to main stalk leaving about 1-2cms space from the 'trunk'. Use a sharp flat blade kitchen knife if the tuber is thick, just to make sure you get a clean cut. Minimise the surface area on the stalk ( cut perpendicular ) as they lose moisture for a while due to the cut. Dose with seasol and molasses before pruning. M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 DIY, Home Maintenance & Repair Plumber or renovation companies are good choices. But it is highly recommended to get the proper from cost estimators or contractor's team to deal with the perfect… 0 1248 Hi, We completed our house build in Dec 2019. Shortly after, our builder went into liquidation so our house defect repairs were covered by the Building Insurance Policy.… 0 515 Hi we have just moved in at start of January very happy with the build. But are soon to be new neighbours have started there build with ustlye homes and are at the slab… 0 1880 |
