ground cover for slope
I've recently had my back yard flattened, half way up
Here is a post of previous pics
I now have a large slope, about 20m wide, from 2.5m to 1m high of loose soil that needs to be fixed.
I also have 2 dogs, what can i use for a short term solution and what should i plant there to fix it permanently?
https://forum.homeone.com.au/viewtopic.php?p=97949#97949
An excellent choice would be drosanthemum pink champagne. This is a fleshy leafed ground cover that is tougher than Mr T
In the summer it will put on a flower show second to none. A carpet of mauve-pink flowers with very little leaf showing through. This is commonly seen in coastal perth suburbs in Particular along westcoast highway. When the show is on, that is all people want
anyone know if it will it grow in outer eastern melbourne?
similar climates to perth so don't see why not
isn't emerald in qld?
and yes the plants I have suggested will do very well in Melbourne in the hills or anywhere for that matter.
I know where they are grown (wholesale nursery) here in WA get many frosts and they do fine
3
A survey must’ve completed by a certified surveyor. This form part of every DA requirement
11/08/2023
Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right…
25/02/2024
Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for…
