Browse Forums Landscape & Garden Design 1 Sep 23, 2008 10:30 am Hi All
Last night due to heavy wind, the hot water system’s lower cover was opened and the burner was having no flame. I restarted it successfully by reading instruction on the cover. But today morning again the water was not hot as it should be, I check and found that there is no burner flame but the PILOT FLAME WAS STILL ON I try to follow the instruction but burner didn’t started. I check the main gas supply meter and also checked my cooking stove the gas supply was ok. What can be possible problem? I am thinking of 1. If it has to do something with electricity I will check its fuses in the main board 2. gas supply to hot system is faulty 3. Scaling or burner issue Please let me know what I should do Any troubleshooting techniques Or if I have to call someone to repair please recommend me that as well. Appreciate your help Re: Hot water system - No Burner Flame 2Sep 23, 2008 8:16 pm When you restarted the unit, did the flame come back on or was it just the pilot? the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13395 Hi All It has been a few weeks since my last update. The build has been progressing well. No major issues to report. The scaffolding was dropped today, gyprock will be… 96 356938 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20224 |
