Browse Forums Landscape & Garden Design Re: Backyard Drainage Issue...Need suggestions 3Jul 15, 2019 2:34 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Backyard Drainage Issue...Need suggestions 7Jul 15, 2019 4:21 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Backyard Drainage Issue...Need suggestions 8Jul 15, 2019 10:05 pm Can you post your drainage site plan. It will also be helpful if you have your site plan with relative levels and handdraw or markup a photo showing the pipe location. What's likely is that your soil is clay, and when the drainage line is excavated to lay the pipe, the plumbers back fill with aggregate and thus create a "French drain" of kinds. This side effect creates an absorbsion trench that can soak and channel surface run off / and sub surface water from "uphill". Take in the higher ground above your site, and note where runoff and other sources of stormwater come from along with runoff on your own plot. You can also create mounds / swales of soil to direct runoff to your drains rather than into your trenches. Re: Backyard Drainage Issue...Need suggestions 9Jul 18, 2019 5:33 pm SteveMc Can you post your drainage site plan. It will also be helpful if you have your site plan with relative levels and handdraw or markup a photo showing the pipe location. What's likely is that your soil is clay, and when the drainage line is excavated to lay the pipe, the plumbers back fill with aggregate and thus create a "French drain" of kinds. This side effect creates an absorbsion trench that can soak and channel surface run off / and sub surface water from "uphill". Take in the higher ground above your site, and note where runoff and other sources of stormwater come from along with runoff on your own plot. You can also create mounds / swales of soil to direct runoff to your drains rather than into your trenches. Hi Steve, Thanks for your response. Can you please clarify last paragraph in more details pls, as I am not good with drainage terms. I've attached a picture of site drainage plan - blue dots are the surface points, orange are 2 extra surface points which were laid at a later stage, and hence not included in actual drawings. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Backyard Drainage Issue...Need suggestions 10Jul 18, 2019 5:34 pm SaveH2O rockford246 SaveH2O STEP 1: Mix some dark colour food dye into a 20 litre bucket of water and pour it down the pipe. STEP 2: Observe over the next few hours/days. Thanks for the response. You mean to say pour dyed water in stormwater drainage pipe and observe that water comes in the trench or not? Bingo. You first need to either confirm or eliminate the pipe as the source. hey mate..I've tried this, and can confirm pipe is the not the source of leakage. Any other suggestions/recommendations which I could try or as SS to look for ? Re: Backyard Drainage Issue...Need suggestions 11Jul 18, 2019 9:24 pm Quote: It will also be helpful if you have your site plan with relative levels and handdraw or markup a photo showing the pipe location. Thanks for the drainage diagram. That clearly shows trench lines down each side in nice straight lines. Perfect for channeling water. Now we need to understand how the block level slopes from high ground to low ground. Do you have a site survey? Where on this plan is the section that's collecting lots of water? Quote: You can also create mounds / swales of soil to direct runoff to your drains rather than into your trenches. Here's a pic that shows a swale. Hopefully that helps. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You must be new to the internet. You're also the only person anyone here has ever heard of washing their garage wall. I hate to break it to you, there are insects and… 6 4848 Hi, Looking to add an ensuite to one of the bedrooms and make it a Master BR. Please see the attached current floorplan. Need suggestions on what's the best way to do… 0 7339 DIY, Home Maintenance & Repair That laser level looks lovely! We bought one for less than a quarter of that price off eBay. It worked really well for us and it's still going now, five years later. After… 1 16711 |
