Browse Forums Landscape & Garden Design 1 Jun 13, 2019 1:10 pm Hi everyone, hoping someone may be able to give some advive. We are currently building a new house with a subfloor supported on concrete stump. The cladding is JH Scycon Linea fibrous cement weatherboards. My front path needs to be about 1/2 way into the lowest weaherboard (which is about level with the floor beams). The Question: What would be the best barrier between the house and weatherboards? I was thinking of 50mm Concrete Sleepers ?? Any ideas? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi, I am currently in the process of getting my driveway done and side paths concreted. After researching i found out that the side paths need to slope away from the… 0 9365 The weep holes are 150mm above the ground. Yes, I thought that the path would have to pool water to drain, however, the path is sloped so it won’t pool water. 4 918 |
