Browse Forums Landscape & Garden Design 1 May 29, 2019 6:28 am Hi all, I have a storm water outlet located on my sloping block and hoping for some ideas to manage, as I strongly suspect this is my problem to deal with. A retention pond is an option but not sure I will have the funds to have this after the build. A number of neighboring properties have ponds, so Im assuming this may be the best course of action. Are there any other viable options to manage? Once the house is up, I would expect more run off from the roof ect so want to be able to manage this as cost effectively as possible, at least for a few years until I can save up to put in a pond. Red dot indicates position on map Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks, D Re: Storm Water Outlet on Acreage site | Options? 2May 29, 2019 8:20 am ![]() Once the house is up, I would expect more run off from the roof ect Not sure why that would be the case. Wouldn’t the roof area be similar to the ground area below it that was there before the house was built. Moreover, I wonder why you wouldn’t be catching the rainwater that is running off your roof for use in the house and garden? our pool filter backwash goes somewhere els. the owner just emptied the pool water to one of these pipes during winter time using a pump. yes there is a toilet right… 6 3570 Plan attached - does it helps? Also checked with council they have advised there was enough fall on the block. Your builder might have deep cut done which caused level to… 5 1682 |
