Browse Forums Landscape & Garden Design 1 Sep 17, 2008 4:10 pm Hi all
this is my very first post.. been watching this site for a while and has been great I need to think of something to retain this wall.. behind it there is a 1.8M high rendered fence. Was thinking of a rock wall but now thinking some bricks might suit better.. Will these need concrete footing? http://www.abcbricksales.com.au/cgi-bin ... st&Option= I'm open to any suggestions Cheers Cam Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Another retaining wall Question 2Sep 17, 2008 11:05 pm If you lived in WA I'd say limestone would be perfect
It retains everything for us sandgropers Not sure what natural stone would be readily available for you there. Sandstone? Re: Another retaining wall Question 4Sep 18, 2008 11:12 am there is heaps of info about using these blocks for retaining walls on the Hanson website:
http://www.hansonbp.biz/document_get.aspx?id=233 - retaining walls http://www.hansonbp.biz/document_get.aspx?id=234 - how to: retaining walls http://www.hansonbp.biz/document_get.aspx?id=272 - Hanson segmental retaining wall systems: technical specifications for commercial and residential applications http://www.hansonbp.biz/document_get.aspx?id=255 - Installation procedures for Hanson segmental retaining wall systems hope that helps! Plantation Homes - The Meridian - http://ourmeridian.blogspot.com/ Re: Another retaining wall Question 5Sep 18, 2008 11:18 am also, if you're looking for someone to build a sandstone boulder wall we used the following guy(s), they did a pretty good job and were reasonably priced
SNW Earthmoving Steve - 0423 249 429 http://www.****/business/sn ... /jimboomba Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Plantation Homes - The Meridian - http://ourmeridian.blogspot.com/ Re: Another retaining wall Question 6Sep 18, 2008 2:17 pm Cameron Hi all this is my very first post.. been watching this site for a while and has been great I need to think of something to retain this wall.. behind it there is a 1.8M high rendered fence. Was thinking of a rock wall but now thinking some bricks might suit better.. Will these need concrete footing? You don't need footings for them if under a certain height, but I would do footings for any wall I build even if using those mortarless type things. Greg Re: Another retaining wall Question 7Sep 18, 2008 5:03 pm damo there is heaps of info about using these blocks for retaining walls on the Hanson website: http://www.hansonbp.biz/document_get.aspx?id=233 - retaining walls http://www.hansonbp.biz/document_get.aspx?id=234 - how to: retaining walls http://www.hansonbp.biz/document_get.aspx?id=272 - Hanson segmental retaining wall systems: technical specifications for commercial and residential applications http://www.hansonbp.biz/document_get.aspx?id=255 - Installation procedures for Hanson segmental retaining wall systems hope that helps! Thanks mate Great info there Re: Another retaining wall Question 9Sep 24, 2008 8:32 am Cameron Just had the front fence done on saturday very happy with it indeed. these pics might show the retainer a bit better.. still not sure what to do Hey Cameron, if you dont mind me asking, but how much did it cost? Re: Another retaining wall Question 10Sep 29, 2008 4:42 pm Hi Snake
40M, 2m High pillars and 1.4M walls was around 16k rendered.. guessing another 4-5k for the sliding gate+fence+small access. Very happy with the job Just stumped on the small amount of retaining .. might build all together with a water feature or something.. Cheers Cameron Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5179 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16138 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6901 |
