Browse Forums Landscape & Garden Design Re: Drainage & Concrete Paths 2Mar 18, 2019 1:46 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Drainage & Concrete Paths 4Mar 18, 2019 3:23 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Drainage & Concrete Paths 5Mar 18, 2019 9:49 pm I've been reading and youtubing but a bit unclear. Can anybody advise the recommended fall? Recommended depth and width of depth for 100mm agi? Socked or not? Geo fabric or not? Bit confused. Would catch basins/pits help? I won't be turfing over the agi drain, instead a decorative rock to assist. Thanks all Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12279 2 5842 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3147 |
