water pump
living on couple of acres the distance from pump to taps/sprinkler will be long
plan on running 1.25" green line pipe but will also need to use 50metres of hose (1"?) from taps to sprinkler
i am considering
davey X70 and bianco iBHM3-6-2V
any thoughts or considerations
thanks
Green line has very close to true ID and 32mm is a good size.
1
This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite…
