Browse Forums Landscape & Garden Design 1 Nov 26, 2018 9:38 pm Hi everyone. I just replaced sugar cane mulch in my garden with some 1inch wide hoop pine bark mulch and have run into a bit of a problem. I watered the garden for close to 30 min tonight then randomly checked some spots in the garden and for the most part the ground was completely dry. The main reason for choosing this mulch was it's supposed ability to allow water to pass through to the soil underneath. I mulched to a depth of 75mm, well below the 100-150mm recommend on most landscaping supply websites. Have I done something wrong or should I have mulched even thinner? Any feedback or assistance would be much appreciated. Photos of garden attached in case they are helpful. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6592 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52859 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10976 |
