Browse Forums Landscape & Garden Design 1 Oct 07, 2018 10:49 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We've just bought a house which has an alfresco area too small to utilise (we think). We thought about just expanding out with a deck and building a pergola but the existing alfresco is roofed and it's support beam would be just plonked in the middle as I don't think it can be removed to expand?? We then thought about just decking a new alfresco/patio along the back of the house instead, building a pergola and decking a path from the existing alfresco to the 'new' alfresco. Torn!!! Any suggestions? Thanks in advance. Re: Roofed alfresco far too small. What to do? 2Oct 08, 2018 7:35 am You can move the post if you put in the right size beam(s) to hold the roof up. The OP has gone The latch and striker are definitely not aligned but there was no point trying to help the OP understand that. Hence the reason they are no longer with us. 12 5695 Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2664 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8285 |
