Browse Forums Landscape & Garden Design 1 Sep 30, 2018 9:18 pm Hi all, I’m hoping someone can please help and shed some light on this please. Visited our site today and fencing has been completed, but it doesn’t look right ??? Fenc meets the garage wall and ends. I thought it would be extended out so that our garage wall is within the fence boundary. But from the photo it appears that our garage wall will be the boundary between us and the next door neighbours land? I’m utterly confused Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: SOS: Fencing and boundary 2Oct 01, 2018 7:26 am That is not an unusual way of doing a boundary like that. Saves a bit of money on fencing costs. The builders/landscapers do however seem to have used a different boundary line at the front! The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: SOS: Fencing and boundary 3Oct 04, 2018 8:30 am imo the garage is set inside by 200-400mm as is usually the case with zero lot builds. That also allows for overhang of the gutter to be within your property. Extending the fence to cover the garage would be an economic waste. You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17163 ask the surveyor for clarification would be the logical approach 1 20135 just talk to them, tell them it is unsightly and ask them for a solution. Any reasonable person would render it for you or do something similar. If they give you trouble… 4 18816 |
