Browse Forums Landscape & Garden Design 1 Sep 06, 2018 7:28 pm I have a section of my brick house which has a garden bed directly against it. I'd like to damp-proof it before I replant. I have a can of bitumen paint but am happy to use other options instead if it's advised? Do I need to dampproof right down to the bottom course of bricks? I've dug out to about four courses and there still seems to be more bricks - I've already filled two bins with soil! Also, are there any alternatives that I should be considering other than bitumen? TIA DIY, Home Maintenance & Repair I don’t have a product to recommend, but you could search the Internet for "professional grade masonry sealer" or speak to a local masonry specialist. 3 998 You can also have a box gutter which sits on the inside but a lot of builders dont like them as if they arent installed correctly they tend to overflow and leak, but if… 5 546 I think you are a bit too close to the top of the wall for such a wide opening. If you just cut a hole in the wall that wide you may lose all the brickwork above it. If… 1 763 |
