Browse Forums Landscape & Garden Design 1 Jul 15, 2018 4:59 pm Hi h1, This is probably a basic question but I just want to make sure I am doing it right. I am planning to plant a few small plants next to my driveway and pebble around the plants. To prevent weeds from growing I am planning on putting a layer of roadbase on top of the soil and weed mat. I'm just unsure as to how I put the plants in - should I leave them in their plant buckets or should I take them out and make a hole through the weedmat and roadbase so that the roots are touching the soil underneath? Or is there any other method you'd recommend? Thanks SS Re: Pebbles around plants 2Jul 15, 2018 6:49 pm Certainly take the plants out of their pots and plant them directly in the ground, that way the root ball can spread out and you won’t need to water them so often. If the plants are small, then just cut an appropriately sized cross in the weed mat and slip that over the plant after you have planted it. I don't think you need to use the road base on the weed mat and can just use the pebbles as the mulch directly over the mat and around the plant, but that’s up to you. Murraya could be a great option for you. It creates a great tall screening hedge but doesn't drop fruit like lily pilly. The flowers smell divine. 2 7964 There is evidence of water on the head reveals. That could have happened during the build, or may be happening currently. There are water stains above a couple of windows… 2 2678 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 4212 |
