Browse Forums Landscape & Garden Design 1 May 31, 2018 9:10 am Hi, Have just laid Matilda Buffalo this week. New build so did not have an option to wait for warmer weather as we had a bare yard that would have turned into a mud heap if we got a lot of rain. Had the area scraped and then put down turf underlay. The grass looks good but am a bit worried that the temperature has dropped to single digit figures this morning here in south west Sydney. Usually do not get frosts. Is there any problem laying turn in Autumn - Winter, the supplier says no as long as you keep it well watered Any information greatly appreciated Col Re: Just Laid Matilda Turf atthis time of year 2May 31, 2018 9:35 am As long as you keep the water up to it as the supplier said, it will be ok. Anytime of year is ok to lay turf, it’s just that Spring, Summer & Autumn are the best times to lay it. In 1-2yrs no one will be able to tell what time of yr it was laid. Re: Just Laid Matilda Turf atthis time of year 3Jun 01, 2018 6:48 am Hi, as you are dropping to single digits over night, I’d be mindful of the time you are watering. You don’t want to leave it too late in the day/evening to do it or it will be still wet when the frost hits and it will affect it Good luck Building our forever home! Building in Stone Ridge with CMA - Follow my build: https://forum.homeone.com.au/viewtopic.php?f=31&t=85842 I had new concrete laid, extended the alfresco and had the sidewalks concreted too. I noticed the concreter didn't put the expansion foam anywhere, there are expansion… 0 8100 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10105 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5791 |
