Browse Forums Landscape & Garden Design 1 Apr 07, 2018 4:19 pm Hi, just had both my front and back lawns laid with Sir Walter Buffalo. The front has taken perfectly and is healthy and lush but the back has become a mess very quickly. We are watering for the amount of time advised by the guy that laid it so are at a loss as to why the front is so good and the back so unhealthy. I believe we must be over watering. Its a bit upsetting as we spent quite a bit to get a mess nicely cleaned up. Any advice on how to turn this around an Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ d revitalize would be very gratefully received Re: Any Sir Walter Buffalo experts out there? 2Apr 10, 2018 9:03 am Chris Moon Hi, just had both my front and back lawns laid with Sir Walter Buffalo. The front has taken perfectly and is healthy and lush but the back has become a mess very quickly. We are watering for the amount of time advised by the guy that laid it so are at a loss as to why the front is so good and the back so unhealthy. I believe we must be over watering. Its a bit upsetting as we spent quite a bit to get a mess nicely cleaned up. Any advice on how to turn this around an Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ d revitalize would be very gratefully received Turf needs to be kept damp but not wet! Lift up a piece of turf before watering and see if soil is moist. If so don't water. Are you able to take a close up pic of grass leaves - it could be a fungal issue also. Re: Any Sir Walter Buffalo experts out there? 3Apr 19, 2018 2:59 pm Thanks! Have altered the advised watering times and now starting to bounce back. Seems we may have flooded it! Appreciate your help Re: Any Sir Walter Buffalo experts out there? 4Apr 19, 2018 3:53 pm Chris Moon Thanks! Have altered the advised watering times and now starting to bounce back. Seems we may have flooded it! Appreciate your help Great! A weekly drink of liquid feet will green it up quickly also. Re: Any Sir Walter Buffalo experts out there? 5Apr 19, 2018 3:53 pm Littlegem Chris Moon Thanks! Have altered the advised watering times and now starting to bounce back. Seems we may have flooded it! Appreciate your help Great! A weekly drink of liquid feet will green it up quickly also. Liquid fert!! Hello I've just bought a house where the slab is lower than the street, (but roof is higher than the kerb). So there's some negative grade at the front. The yard very… 0 8507 I carefully examined the ceiling of the room beneath the balcony and did not see any obvious signs of water… 6 9786 Thanks for the informative response! I'll feed that back to the site supervisor. 2 12377 |
