Browse Forums Landscape & Garden Design 1 Feb 13, 2018 8:53 am Hi, Having recently completed a build, we are about to commence work on laying sandy loam fill and also Sir Walter buffalo turf in our back yard. In considering drainage/grading our our turf, I believe I may need to do something with this (see pic below). Anyone know what this is? We have 6 of these things in our back yard. I am guessing (purely guessing) they may be storm water drains for my backyard. I have asked our builder (Arden Homes), but they are yet to come back to me. If they are drains, what do I need to do with it to work effectively, i.e. grade the lawn towards it and fit a drain on it? Any help would be appreciated and also a picture of a finished product would be great too. TIA. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: What is this - storm water drain? 2Feb 13, 2018 9:32 am if you have six of them they would be stormwater, check against your drawings for layout of stormwater drains to confirm. Yes grade your surface levels toward the drain, cut it and fit prefab plastic drain pit at the lowest point. Another way to tell would be to measure the diameter. Stormwater is 90mm ,sewer 100 although some stormwater is laid in 100mm. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: What is this - storm water drain? 3Feb 13, 2018 9:52 am building-expert if you have six of them they would be stormwater, check against your drawings for layout of stormwater drains to confirm. Yes grade your surface levels toward the drain, cut it and fit prefab plastic drain pit at the lowest point. Another way to tell would be to measure the diameter. Stormwater is 90mm ,sewer 100 although some stormwater is laid in 100mm. Thanks for that - I will now go ahead and buy appropriate storm water pits for the pipes. Appreciate your help! Re: What is this - storm water drain? 4Feb 13, 2018 6:35 pm I have two such risers which are inspection/ openings for the storm water pit in my back yard. You can level them with your finish surface of the lawn or as BE stated use as additional surface drains to your pit. In my case it's pointless as the level in my backyard slopes further downhill. just pop the caps off and look down. Re: What is this - storm water drain? 5Feb 19, 2018 8:15 pm Jeeta23 Hi, Having recently completed a build, we are about to commence work on laying sandy loam fill and also Sir Walter buffalo turf in our back yard. In considering drainage/grading our our turf, I believe I may need to do something with this (see pic below). Anyone know what this is? We have 6 of these things in our back yard. I am guessing (purely guessing) they may be storm water drains for my backyard. I have asked our builder (Arden Homes), but they are yet to come back to me. If they are drains, what do I need to do with it to work effectively, i.e. grade the lawn towards it and fit a drain on it? Any help would be appreciated and also a picture of a finished product would be great too. TIA. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I’d be very interested in Arden’s response Jeeta, as we are talking to a landscaper now. Wonder what happens if they are where you want to do concrete? Re: What is this - storm water drain? 6Feb 19, 2018 8:30 pm Jeeta23 building-expert if you have six of them they would be stormwater, check against your drawings for layout of stormwater drains to confirm. Yes grade your surface levels toward the drain, cut it and fit prefab plastic drain pit at the lowest point. Another way to tell would be to measure the diameter. Stormwater is 90mm ,sewer 100 although some stormwater is laid in 100mm. Thanks for that - I will now go ahead and buy appropriate storm water pits for the pipes. Appreciate your help! But isn’t the stormwater channeled to the legal point of discharge? Eg. Front curb drain? Re: What is this - storm water drain? 7Feb 20, 2018 7:13 am Ezza78 Jeeta23 Hi, Having recently completed a build, we are about to commence work on laying sandy loam fill and also Sir Walter buffalo turf in our back yard. In considering drainage/grading our our turf, I believe I may need to do something with this (see pic below). Anyone know what this is? We have 6 of these things in our back yard. I am guessing (purely guessing) they may be storm water drains for my backyard. I have asked our builder (Arden Homes), but they are yet to come back to me. If they are drains, what do I need to do with it to work effectively, i.e. grade the lawn towards it and fit a drain on it? Any help would be appreciated and also a picture of a finished product would be great too. TIA. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I’d be very interested in Arden’s response Jeeta, as we are talking to a landscaper now. Wonder what happens if they are where you want to do concrete? Hi Ezza, I spoke to Arden and my landscaper, they confirmed like the gentleman above, that these are storm water pits. I need to grade my landscaping to feed into these drains. Likewise any concreting will need to be graded/sloped slightly enough towards the drains.My landscaper will fir a pit on it too. Arden advised me to not bury these drains (that was never my intention). Re: What is this - storm water drain? 8Feb 20, 2018 7:16 am Ezza78 Jeeta23 building-expert if you have six of them they would be stormwater, check against your drawings for layout of stormwater drains to confirm. Yes grade your surface levels toward the drain, cut it and fit prefab plastic drain pit at the lowest point. Another way to tell would be to measure the diameter. Stormwater is 90mm ,sewer 100 although some stormwater is laid in 100mm. Thanks for that - I will now go ahead and buy appropriate storm water pits for the pipes. Appreciate your help! But isn’t the stormwater channeled to the legal point of discharge? Eg. Front curb drain? Hi Ezza, It may differ from my area to your (as your one was a KDR), I can confirm mine is connected to the underground storm water discharge for our estate. Re: What is this - storm water drain? 9Feb 20, 2018 9:14 am Jeeta23 Ezza78 Jeeta23 [quote="building-expert"]if you have six of them they would be stormwater, check against your drawings for layout of stormwater drains to confirm. Yes grade your surface levels toward the drain, cut it and fit prefab plastic drain pit at the lowest point. Another way to tell would be to measure the diameter. Stormwater is 90mm ,sewer 100 although some stormwater is laid in 100mm. Thanks for that - I will now go ahead and buy appropriate storm water pits for the pipes. Appreciate your help! But isn’t the stormwater channeled to the legal point of discharge? Eg. Front curb drain? Hi Ezza, It may differ from my area to your (as your one was a KDR), I can confirm mine is connected to the underground storm water discharge for our estate.[/quote] Thanks Jeeta, do it’s like the storm water drainage is set up, we just have to finish it with our landscaping. So we can direct water to the storm water drains? Thanks heaps Re: What is this - storm water drain? 10Feb 20, 2018 9:31 am Ezza78 Jeeta23 Hi Ezza, It may differ from my area to your (as your one was a KDR), I can confirm mine is connected to the underground storm water discharge for our estate. Thanks Jeeta, do it’s like the storm water drainage is set up, we just have to finish it with our landscaping. So we can direct water to the storm water drains? Thanks heaps No worries Yes, essentially that what it is - a storm water drainage system for property. If it is done the right way, it will protect your slab from water issues too. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7809 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6841 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10464 |
