Browse Forums Landscape & Garden Design 1 Oct 30, 2017 2:55 pm I have never really thought about this, however one of my friends had me concerned about the issue. I excavated my backyard land about a metre in depth (I now have 5 standard masonry blocks - 190mm high as which are acting as a retaining wall), for an extension my architect had designed at the back of my house. It involved extending the ground floor granny flat for a rumpus room and balcony, and the upper floor for a family room which will have a breakfast bar extending out and connecting from the kitchen and inside the room will also have a small bath and laundry, plus a balcony on the other side of the house. The construction is almost finished, however it has cost me a lot of time, money and headache. One of my friends told me I should have not excavated my backyard as it would decrease my land value. Whilst I was aware of this, I had informed of a property evaluator of my plans for the extension prior to construction and they advised me that everyone has a different taste and there isn't a certain rule of thumb. What are your honest opinions? Re: Does Lowering Backyard Land Decrease Property Value? 2Oct 30, 2017 7:29 pm Unless you've created a drainage issue and risked the structural integrity of the building, then it's just as you mentioned... Fashion/taste/style. Landscaping is usually to the home owners liking which rightly is to be expected. Don't pay any credit to those negative opinions, the point isn't to build for others, but rather to your own purposes. Re: Does Lowering Backyard Land Decrease Property Value? 3Oct 31, 2017 2:44 pm SteveMc Unless you've created a drainage issue and risked the structural integrity of the building, then it's just as you mentioned... Fashion/taste/style. Landscaping is usually to the home owners liking which rightly is to be expected. Don't pay any credit to those negative opinions, the point isn't to build for others, but rather to your own purposes. The water is now pumped out from a pit as the land at the back is lower than the front - the only reason for me asking is because i will be selling Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24831 As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is… 3 27344 They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9578 |
