Browse Forums Landscape & Garden Design 1 Oct 02, 2017 5:34 pm I ended up installing an iriigation sytem got hunter mp3000 rotators but the guy at the irrigation shop just sold me the standard pro spray bodies so no check valve or pressure correction. One makes a hissing noise and is loud im assuming its air in the system and the lowest one leaks all the water out of the pipe when i urn off im hoping the check valve will stop this issue. I have 4 mp3000 rotators installed and was hoping for efficiency. Would this be about correct I turn my tap on only a bit more than half a turn and I read my meter over one minute Im getting charged for 13litres does this sound about right and is this efficient as if I run for an hour which I probably will need to do in the heat of summer this is closing in on 1 kilolitre just for front lawn watering? I liek the product but the radius adjustment is not the best I probably could have got away with mp2000 anyway the guy at the shop said dont mix and match so I went with mp3000. The noisy on is the closest one to the incoming water I have a t piece going to the lower one at the front and then the other 3 are fed from the other end of the t piece the water natural flow would be down to the 1st one im thinking maybe thats why that one is noisy hissing air noise etc. Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19521 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9797 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14073 |
