Browse Forums Landscape & Garden Design 1 Sep 17, 2017 4:53 pm Hi Guys Any ideas on what could be the issue with this rose bush (Charles de Gaulle)? The other ones to either side (Dolly Parton and Buccuneer to the left and Virgo and Double Delight to the right) are fine and the leaves are dark green, but this one looks like it's dying. I feed it Black Marvel and have cane mulch around it. Thanks in advance. PS Sorry for the poor quality photo. Charles de Gaulle Rose Bush Looks Sick.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Rose Bush Question 2Sep 17, 2017 7:42 pm Looks to me like it's got black spot. Could be something to do with that sprinkler next to it, when watering roses, should always water the rootball only, and try not to water across the leaves etc Re: Rose Bush Question 3Sep 17, 2017 8:14 pm Thanks. I'm move the sprinkler and have a look at what's good for treating Black Spot. Re: Rose Bush Question 4Sep 17, 2017 10:31 pm Best thing is to cut off the affected sections, and then use a black spot spray regularly to prevent reoccurrence. You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9959 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6150 1 13123 |
