Browse Forums Landscape & Garden Design 1 Aug 15, 2017 2:06 pm Hi, I am in the process of returfing my lawn, i have just stripped 100mm off the top of the yard as it was a very hard clay (Brisbane) ive just finished spreading 100mm layer of a blood and bone underturf through the yard and gardens. I have since found this forum and read a thread by fu about the correct way of doing it, using compost instead of underturf and tilling zeolite and perlite etc. Ive just finished leveling it all out. 20m3 total of the underturf. Since reading fu's posts I am now having concerns about laying turf over the top. If i get compost and zeolite etc to the recommended quantitys the levels will be way to high which will lead to removing a heap again. Whay is my best course of action now? Is removing it and starting again the only way? Also would a plate compacter be wise to use on a clay mix? Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7006 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4121 |
