Browse Forums Landscape & Garden Design 1 Aug 13, 2017 10:51 am Hi there just wondering if there's any concreters or someone with some concrete knowledge that could give me some much appreciated advice. My wife and i are about to get handover of our house in a couple of weeks and pretty soon after it we need to get a heap of concreting done but we have a couple of issues to deal with. First one being that we have an annoying small retaing wall down one side of the house and a water tank that is sitting on a slab of concrete where we want to lay a path down, here are a couple of photos Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The problem is that the retaining sits roughly 30mm lower that slab that's there and i'm really not sure what to do here. I have a had concreter out to messure out all the areas that i need done but he says that i need to get this sorted before he can do anything as he says that he can't just concrete over the retaining wall, is that true ? Or do i need to need to build up the retaing wall to the height of the slab ? Second issue is this Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is at the end of the other side of the house near the corner of our alfresco and that drain is a storm water drain. Do i need to put a retaing wall there and would i need to get a permit for that ? I know these are probably silly questions but we're first time builders and we've never had to deal with any of this stuff before so any advice would be very much appreciated. Cheers Re: CONCRETE AND RETAINING WALL ADVICE NEEDED : 2Aug 13, 2017 11:01 am you could pull up retaining wall and use deep concrete beam at fence as part of your paving, however be careful of drainage you will need a spoon drain along the fence. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: CONCRETE AND RETAINING WALL ADVICE NEEDED : 3Aug 13, 2017 12:18 pm building-expert you could pull up retaining wall and use deep concrete beam at fence as part of your paving, however be careful of drainage you will need a spoon drain along the fence. Re: CONCRETE AND RETAINING WALL ADVICE NEEDED : 4Aug 13, 2017 4:50 pm your concreter should be able to do it Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: CONCRETE AND RETAINING WALL ADVICE NEEDED : 5Sep 02, 2017 2:00 pm Patto we had a similar setup, just had a concreter out to look at it - we'll leave a 200mm gap between the concreting and the retaining wall. Be much easier if we ever need to replace the retaining, and it will help the drainage too. Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18221 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45838 |
