Browse Forums Landscape & Garden Design 1 Aug 24, 2008 12:15 am I picked up a second hand 8 person spa about a year ago. We've pulled all the old cracked & perished plumbing off and will be refinishing the surface ourselves. I'll be paying a spa plumber to redo all the pipes and filters / pumps etc etc
I'd like to set it partially into the ground (bottom 3rd) and support the rest with a metal frame covered with timber decking. Do I need to pour a slab for the bottom of the spa as well as to support the frame? Any links to install requirments? Just doing my research at this stage so I can plan and be ready. Timbacare - Save Your Furniture! We can help you revive timber furniture & flooring www.timbacare.com.au Re: Spa Install hints & tips anyone?? 3Aug 24, 2008 10:18 pm Yep ... I'll be packing heaps of insulation around it but we're mostly going to use it as a cool mini pool for summer. It will only be heated occasionally.
I've never installed a pool or spa before so any other hints will be most welcome. Hint hint!! Timbacare - Save Your Furniture! We can help you revive timber furniture & flooring www.timbacare.com.au Re: Spa Install hints & tips anyone?? 4Aug 24, 2008 11:33 pm http://www.wcc.net/~jkmccoy/hottub/hottub.htm
http://www.angelfire.com/mi2/hottubs/plumbing.html http://www.poolspahelp.com/spa_plumbing_diagram.htm http://www.onga.com.au/www/109/1001127/ ... 01227.html http://spaforums.com/Spa_Hot_Tub_forum_ ... ts_41.html http://www.solazone.com.au/polysola.htm http://www.hurlcon.com.au/tech.html maybe some of these will help? Re: Spa Install hints & tips anyone?? 5Aug 25, 2008 12:16 pm Wow ..... now that's got to help!
Got a few night reading to do and lots of notes to take. That was great. Thank you VERY much! Timbacare - Save Your Furniture! We can help you revive timber furniture & flooring www.timbacare.com.au 3 3554 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7215 Thank you so much. This has been very helpful. We definitely wish to settle and get these people out of our life. They are trying to charge us interest on late… 7 14242 |
