Browse Forums Landscape & Garden Design 1 Apr 25, 2017 4:04 pm Hey everyone, We are new to building so apologies if this has been answered before! We are building a single level house. We haven't had an offical site inspection yet as we are still having the exterior done so have only been visiting the property in the weekend ( I think you're not suppose to! ). Our land was totally 120% as flat as flat could be when we bought it. When they've done the slab they have build up the soil/dirt on the block and laid the slab that way. Looks like our neighbours are as well. Any reason thy do it this way? Or is that normal? I am struggling to envision our backyard. We will be decking over the alfresco, extending it by about a metre and a half and wrapping it under the meals window and under the door and stopping there and having stairs go off it. We do not want to add soil and build the yard up to level as that will entail a retaining wall at the back and our builder has said on our original plans we will only need retaining wall at the sides. Any ideas on what can be done when we get to landscaping? Is this a tricky job? Thank you! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17527 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6595 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46965 |
