Browse Forums Landscape & Garden Design 1 Aug 17, 2008 3:58 pm Hi,
I am trying to get ideas of how i can bring my idea to reality. Last year we had new retaining walls installed for our garden beds around the pool area. The next phase of the landscaping is to redo the pavers around the pool and install some benches and pebble bordering similar to the ones in the attached picture. A consideration that i am throwing around is that maybe the retaining wall is not thick enough to support the weight of the bench idea. Maybe i might need to mount the benches flush against the wall and have the benches concreted into the ground. Has anyone seen any bench kits (brackets and treated pine) that may suit? Perhaps someone might be able to give me some more suggestions on alternatives? The idea: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is our area after the retaining walls were installed: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Garden/Poolside Bench Ideas 2Aug 18, 2008 8:32 am attach the bench's to the steel uprights Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11707 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31278 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3803 |
