Browse Forums Landscape & Garden Design 1 Apr 09, 2017 11:36 pm Hi, I have finished building my raised planter box/retaining wall and now looking for advice for the best soil to use to plant mainly fruit trees (apple, nectarine, cherries, avocado etc) and citrus trees. I am located in Sydney and I had a look at ANL's website but they sell multiple mixes. I will need to fill around 8cubes so buying 20litre bags from bunnings will be too expensive. Max depth of the planter box is 800mm. Cheers and Thanks ! Re: Bulk Soil for raised planter box- Citrus and fruit trees 2May 01, 2017 6:41 pm It's only the top 400mm you want to worry about. Plant roots will not populate soils below that depth (often) because oxygen is too low. Try choose something that is a little sandy and has certified organic content. You may need to build that yourself using white washed sand, zeolite, organic compost, Coir peat. A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223606 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28812 I brought terry road box hill in June 2022 House was meant to be completed Nov 2023 That did not happen I had to chase them so much to the land Registration and… 0 2503 |
