Browse Forums Landscape & Garden Design 1 Dec 17, 2016 4:04 pm I've recently pulled out 6 Little Gems from a garden bed...have also made it slightly larger. The beds are about 900mm high and the depth has fallen by about 200mm...so I need to raise the height of the soil. Not sure what to top up with...maybe a 5 blend mix (http://www.cfulton.com.au.sdwt.com.au/c ... ded-soils/) or just straight compost (http://www.cfulton.com.au.sdwt.com.au/c ... d-manures/) ? I'm probably going to put some smallish trees back in the space. Any advice appreciated. Re: Soil or compost top up? 2Dec 18, 2016 8:53 am If the soil already there is okay (ie not too sandy or clay) i would top up with a soil and compost mix and mix it all through the existing if can. If you mix through the existing soil it will compact and drop a little so account for that. Remember to leave room for a good beneficial mulch too 0 24719 ![]() I have a toilet that blocks up on the top (2nd) floor of a property. The toilets on the 1st and ground floor are OK) Blockage clears when the using a plunger. But… 0 13138 |
