Using 'Fresh' Cow Manure
My soil is sandy loam, & could do with some manure turned in to it - and I have plenty on hand, lol!
Apparently a good idea is to put some in your compost heap and after 2-3 months it should be ready.
Peter Cundall always appears to use processed pelletised manure on Gardening Australia.
Maggie
Cheers
Maggie
Those comments are so right.
Seeds are also stimulated into germination when the soil is disturbed. They may have lay there for years and when someone decides to get in there and spruce up the garden those seeds are sometimes brought to the surface and exposed to water (which is what most will do when finishing a garden project;))
On the topic of fresh cow poo. I will never recommend using it as a means of prepping the soil for planting.
Why? because of a few things. When you buy the cow poo, you don't know for sure if it is fresh or rotted. The same brand can vary in the age of it's contents throughout the year. I know of some brands sold that contain guaranteed rotted poo, but they are few and far between.
If the poo is fresh then the acids in the cow poo can burn the delicate roots of a new plant. The same can be said for chook poo or sheep poo or zoo poo
It does break down rapidly in the soil. This means that you can be left with a hole in the ground of much the same quality as it was before the prep in a matter of months. When planting always use a high quality soil improver/ conditioner that meets the premiums Australian standards (red ticks) Bailies soil improver here in the west is a fantastic one which contains a certified organic soil called Biowise among other great things. These are more permanent soils that hang about much longer giving the plant a better chance in life. (also don't forget the Seasol;))
I recall a chap years ago who swore his sheep poo was disappearing from the soil (sand
However fresh cow poo is of a very great benefit in reinvigorating the soil. Just spread it on the surface in a very thick amount, pull it away from the stems so as not to rot the stem (causing some not cool things) and let the water take the goodies through to the roots and deeper soil. I don't often suggest digging much into the soil because of damaging surface roots of plants. just an unnecessary hassle for the plant to have to spend energy repairing damaged roots, you want it to spend energy getting more foliage and recovering from any pruning.
i am also mucking around with Molasses to bring the soils micro ecology to life! I am getting some excellent results! It is so cheap but that's another topic
2
Broker here - legislation says that every true broker must put the clients best interests before theirs so in theory they must offer you the best options for you on their…
7/02/2024
Anyone using Bellriver bulder and doing the turnkey projects
