Browse Forums Landscape & Garden Design 1 Oct 10, 2016 9:52 pm I am needing some advice. We are needing to retain close to a yet to be completed driveway and I unsure which if any should go first. Should the retaining wall be done first as there will be more room on site etc or can we do the retaining wall after construction of the driveway as then we will have the final ground leval and know exactly how high the wall needs to be. Driveway will have piers underneath to prevent excess movement from the soft fill present around the edge. This picture shows driveway Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Retaining wall needs to be 1m of each boundary according to council requirements. showing area needing to be retained. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ sekisui build viewtopic.php?f=31&t=75060&p=1573965#p1573965 Building a sekisui house in Holmesville NSW viewtopic.php?f=31&t=75060 I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 36944 That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81896 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7306 |
