Browse Forums Landscape & Garden Design 1 Aug 14, 2016 10:14 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Would love some advise about this shrubby rose. It looks shabby with all of the dead branches underneath, but I fear that if I hack them out, then it will topple over. ' As you can see, not much of it is living now anyway - has this plant come to the end of its life? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice needed on shrubby rose 3Aug 14, 2016 12:22 pm It is winter so it naturally looks crappy. Cut it back far enough so when you take out the dead stuff it doesn't fall over. Give it a feed, it should be budding in a 2-4 weeks. Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7011 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17982 |
