Browse Forums Landscape & Garden Design Re: Retaining Wall Advice/Help/Opinions/Comments 3Jul 29, 2016 7:25 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Retaining Wall Advice/Help/Opinions/Comments 5Jul 29, 2016 10:13 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Retaining Wall Advice/Help/Opinions/Comments 7Sep 19, 2016 3:03 pm Stewie D Quote: I'm a bit concerned for my agline as I don't think its worked at all even though I had a generous fall and backfilled with gravel it was socked agline and I used geofabric. Nothing ever comes out the end of the pipe. Did you use proper slotted 90mm stormwater pipe http://www.iplex.com.au/iplex.php?page= ... =13&sec=86 or the all too often used but cheaper flexible pipe ? viewtopic.php?f=19&t=78548&p=1396277#p1396277 Stewie I am curious - how much difference in performance is between the two types of pipe? Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17638 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6901 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45798 |
