Browse Forums Landscape & Garden Design 1 Jul 10, 2016 7:26 pm we are building with clarendon homes and the land is flat but we were told we are required to have a retaining wall built..can someone explain why we need one if the land is flat? and what is the cost of one for land that is 30m long? the lady told us we need to have a retaining wall built on both sides of the house building in oran park stage 21C killara 26 model with clarendon homes Re: building a retaining wall? 2Jul 10, 2016 7:43 pm Hi tony Do you have a contour survey that shows the house FFLs etc More info is required Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: building a retaining wall? 5Jul 11, 2016 7:03 am Didn't they discuss the optimum finished floor level heights (FFL) with you? On cut and fill there generally is a balance point where optimum FFL (cut = fill ) this minimises soil cartage too and from the site, the height difference compared to the Natural Ground level should be retaining. On flat land if you cut you will need to dispose excess soil and put in retaining worse still if you are on the boundary a triple whammy in Co$ts. The Building Information Model (BIM) 3D software they use to produce the fancy Elevation renderings should be able to work out balance point. Did they optimise the FFL in order to reduce your site works costs...the question is why not?.. the answer is it's extra money for jam not to & basically difficult blocks require expert knowledge which salesman don't have. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: building a retaining wall? 6Jul 12, 2016 9:37 am If you are talking 150mm or less, you can probably get away with just a sleeper in the fence. I did that on one side and it cost about $100 in sleepers. Re: building a retaining wall? 7Jul 12, 2016 10:27 am I'm guessing there is a small amount of cross fall across your block - ask them for a copy of your contour survey. Chances are they are doing an even cut/fill and marked their plans with "retaining wall to be built by owner" so they don't have to charge you for a drop edge beam or extra fill etc that would otherwise make their price look too expensive. http://camdenbuild.blogspot.com.au/ by invite only please pm me Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5193 Hello, We are about to build and the plans show a part of the exterior wall is being built on top of a limestone retaining wall. Does this mean the retaining wall will… 0 6963 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16149 |
