Browse Forums Landscape & Garden Design 1 Mar 28, 2016 9:39 am Hello Everyone we are still conducting our landscaping and are after some peoples opinions on whether to place a frangipani tree in our front yard at the moments its small but as you know these trees can grow very large and awkward. We are unsure whether to place it on the white pebbles near our letterbox or if we just place it on our front lawn somewhere. Our main aim is 1. Not to distract to much attention from the front of our house ie block the front of the house 2. Offer some shade as our house faces north and we get heavy sun all day long Im thinking in the pebble garden behind the letterbox but iam concerned about the roots growing underneath the driveway and ruining it in a few years time when the tree becomes large. [imghttp://i833.photobucket.com/albums/zz260/bsb20092010/IMG_6067_zpsudk9f8ke.jpg][/img] http://i833.photobucket.com/albums/zz260/bsb20092010/IMG_6069_zpsqhkby6pe.jpg[/img] Also into my backyard I was thinking of running a garden bed along the edge of the house main reason is I hate grass growing next to the slab and when you whipper snip it your bricks and mortar turn green. I have limited room already so how wide would one suggest making this garden bed, I already have a retaining wall under construction on the fence side which will most likely also becoming a garden im just thinking it will be to much garden with just a few strips of lawn in between [imghttp://i833.photobucket.com/albums/zz260/bsb20092010/IMG_6070_zpsxiwjvjem.jpg][/img] Re: Landscaping and planting advice frangipani tree? 2Mar 28, 2016 4:22 pm Frangipani's are easy to prune and control, they are also slow growing and they don't have huge roots that are going to damage a driveway. I think it will be fine either way. Re: Landscaping and planting advice frangipani tree? 3Mar 28, 2016 6:17 pm I would say plant the tree on the lawn, in front of the window to the right so it's not centered. If you plant it near your letterbox you won't be able to see your front door when looking straight towards the house. I think houses which have their entrance blocked from view look uninviting. Just my two cents worth Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Landscaping and planting advice frangipani tree? 4Mar 29, 2016 1:49 am I think the lawn is a better placement for window shade and privacy. Frangis are super easy to move as well. Put it where you want, you can move it later if you change your mind Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: Landscaping and planting advice frangipani tree? 5Mar 29, 2016 1:51 am Re garden bed, depends what you want to grow. Maybe 400 to 600mm? Or have it all garden with a meanderinb path down the middle. No whipper snipper required and you could have some larger shrubs . Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: Landscaping and planting advice frangipani tree? 6Mar 29, 2016 7:35 am Just make sure that wherever you plant the Frangipani it is free draining. They hate wet feet. I'd also plant it away from the driveway or path as others above have said as they can drop lots of flowers and leaves in autumn. They can look superb and smell divine. Stewie Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35320 Ha all, I am now about half way (maybe a bit more) through my build with Carlisle Homes - double-storey knockdown/rebuild project. So I am now doing my due diligence and… 0 3716 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17324 |
