Browse Forums Landscape & Garden Design 1 Mar 07, 2016 4:43 pm Hi guys, I have a wooden retaining wall at the front of my house, I'm on a corner plot so it goes along the front then bends around the side, it's made of 4 sections of about 2.5 m long. I want to use HardiFlex to cover the wall and then render it, similarly to how they've done in this example: http://www.coastalcreationslandscaping.com.au/blog/retaining-wall-makeover-in-rye A few questions I had were: I'll have to add more timber to the wall first to make a flat frame, is that correct? Does anything need to go inbetween the timber and the hardiflex sheets? What's the best way to join the boards together as they are going to be at angles as the wall goes around a corner. Thanks in advance for any help Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5140 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9112 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8486 |
